Restoring my 37-116. It plays now!
morzh Wrote:Now I could use some instructions while disassembling and assembling it back.
Does anyone know of any drawing I could use?
Complete factory information for servicing the Philco Automatic Tuning mechanism may be found here:
http://www.philcoradio.com/phorum/showth...p?tid=5938
RE: Starting on my 37-116 - by Ron Ramirez - 06-02-2013, 01:39 PM
Users browsing this thread: 42 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
