Veneer repair and finish advice for Philco 14MX
IF it's not better after your work, you might try spritzing the inside of the cabinet and reclamp.
RE: Veneer repair and finish advice for Philco 14MX - by Art Hoch - 06-02-2013, 02:30 PM
There are currently 10025 online users. [Complete List]
» 2 Member(s) | 10023 Guest(s)
