Philco Model 20
#32
Regarding that extra cap on your chassis, look in the Philco Repair Bench site under service tips. One of the tips explained adding a cap to eliminate high pitched whistling under full volume conditions. This might be the answer to your extra cap. Take care. Gary
Philco Model 20 - by pete7189 - 05-16-2013, 12:34 AM
RE: Philco Model 20 - by codefox1 - 05-16-2013, 01:13 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 06:39 PM
RE: Philco Model 20 - by Arran - 05-16-2013, 07:26 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 09:58 PM
RE: Philco Model 20 - by gary rabbitt - 05-16-2013, 11:34 PM
RE: Philco Model 20 - by Arran - 05-17-2013, 03:03 AM
RE: Philco Model 20 - by pete7189 - 05-17-2013, 07:20 AM
RE: Philco Model 20 - by Mondial - 05-17-2013, 02:15 PM
RE: Philco Model 20 - by pete7189 - 05-19-2013, 11:55 PM
RE: Philco Model 20 - by Arran - 05-20-2013, 01:00 AM
RE: Philco Model 20 - by pete7189 - 05-20-2013, 03:07 AM
RE: Philco Model 20 - by GarySP - 05-20-2013, 11:03 AM
RE: Philco Model 20 - by pete7189 - 05-24-2013, 02:57 AM
RE: Philco Model 20 - by 7estatdef - 05-26-2013, 08:05 AM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 09:48 AM
RE: Philco Model 20 - by pete7189 - 05-26-2013, 06:52 PM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 07:40 PM
RE: Philco Model 20 - by morzh - 05-26-2013, 08:05 PM
RE: Philco Model 20 - by pete7189 - 05-27-2013, 01:11 AM
RE: Philco Model 20 - by Phlogiston - 05-27-2013, 09:34 AM
RE: Philco Model 20 - by morzh - 05-27-2013, 11:24 AM
RE: Philco Model 20 - by GarySP - 05-27-2013, 07:24 PM
RE: Philco Model 20 - by morzh - 05-27-2013, 08:01 PM
RE: Philco Model 20 - by pete7189 - 05-28-2013, 06:27 AM
RE: Philco Model 20 - by 7estatdef - 05-28-2013, 07:25 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 09:30 AM
RE: Philco Model 20 - by morzh - 05-28-2013, 11:08 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 02:09 PM
RE: Philco Model 20 - by pete7189 - 06-01-2013, 02:06 AM
RE: Philco Model 20 - by morzh - 06-01-2013, 11:35 AM
RE: Philco Model 20 - by GarySP - 06-02-2013, 04:22 PM
RE: Philco Model 20 - by pete7189 - 06-04-2013, 10:43 PM
RE: Philco Model 20 - by morzh - 06-04-2013, 10:46 PM
RE: Philco Model 20 - by pete7189 - 06-05-2013, 12:08 AM
RE: Philco Model 20 - by GarySP - 06-05-2013, 12:34 PM
RE: Philco Model 20 - by pete7189 - 06-06-2013, 04:25 AM
RE: Philco Model 20 - by GarySP - 06-06-2013, 12:24 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 10:53 PM
RE: Philco Model 20 - by morzh - 06-26-2013, 11:11 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 11:18 PM
RE: Philco Model 20 - by morzh - 06-27-2013, 01:36 PM
RE: Philco Model 20 - by pete7591 - 09-12-2014, 02:07 AM
RE: Philco Model 20 - by morzh - 09-12-2014, 10:15 AM
RE: Philco Model 20 - by radiohenry - 09-12-2014, 03:53 PM
There are currently 7443 online users. [Complete List]
» 1 Member(s) | 7442 Guest(s)
