38-116 toner colores
No one ever answered your questions on toner, so let me say this: I would use Medium Walnut (Tone Finish) overall, with Perfect Brown (Ultra Classic) on the "white wood" trim.
#03 is probably as close as you will get on the grille cloth, unless Radio Daze offers the original-type #41 again in the near future. It can be seen here on the Wayback Machine in this snapshot of the grillecloth.com site from 2007:
http://web.archive.org/web/2007121402282...es/p3.html
Oh, and good luck on the grain filling - it's my least favorite part of refinishing, also. I'm waiting for some new Constantine's walnut grain filler to arrive so I can try again.
38-116 toner colores - by vinzer - 05-28-2013, 10:12 PM
RE: 38-116 toner colors - by vinzer - 06-02-2013, 09:42 PM
RE: 38-116 toner colores - by Ron Ramirez - 06-03-2013, 05:33 AM
RE: 38-116 toner colores - by vinzer - 06-03-2013, 11:41 AM
RE: 38-116 toner colors - by vinzer - 06-06-2013, 11:26 PM
There are currently 9904 online users. [Complete List]
» 2 Member(s) | 9902 Guest(s)
