37-630 missing parts?
Yes, there should be a total of 10 trimmers underneath the RF subchassis. 4 are in the Osc section closest to the front panel, then 3 in the center RF section and another 3 in the Ant section towards the back.
Which ones are you missing?
37-630 missing parts? - by Jim Dutridge - 06-03-2013, 04:53 PM
RE: 37-630 missing parts? - by Mondial - 06-03-2013, 05:38 PM
RE: 37-630 missing parts? - by Jim Dutridge - 06-04-2013, 09:25 AM
RE: 37-630 missing parts? - by Ron Ramirez - 06-04-2013, 11:30 AM
RE: 37-630 missing parts? - by Jim Dutridge - 06-04-2013, 12:07 PM
RE: 37-630 missing parts? - by Ron Ramirez - 06-04-2013, 12:33 PM
RE: 37-630 missing parts? - by Jim Dutridge - 06-04-2013, 05:06 PM
RE: 37-630 missing parts? - by Ron Ramirez - 06-04-2013, 07:22 PM
RE: 37-630 missing parts? - by Jim Dutridge - 06-05-2013, 12:38 PM
RE: 37-630 missing parts? - by Mondial - 06-05-2013, 08:03 PM
RE: 37-630 missing parts? - by Jim Dutridge - 06-06-2013, 12:32 PM
RE: 37-630 missing parts? - by Jim Dutridge - 07-09-2013, 12:54 PM
RE: 37-630 missing parts? - by Jim Dutridge - 07-12-2013, 10:47 AM
RE: 37-630 missing parts? - by Ron Ramirez - 07-12-2013, 06:37 PM
RE: 37-630 missing parts? - by Jim Dutridge - 07-12-2013, 06:44 PM
RE: 37-630 missing parts? - by Ron Ramirez - 07-12-2013, 06:45 PM
RE: 37-630 missing parts? - by Jim Dutridge - 07-12-2013, 07:21 PM
RE: 37-630 missing parts? - by Jim Dutridge - 08-02-2013, 10:41 AM
There are currently 8410 online users. [Complete List]
» 1 Member(s) | 8409 Guest(s)
