Veneer repair and finish advice for Philco 14MX
After leaving it clamped up for about 2 days, the cup is a little better, but not great. I have thought about wetting the outside, but the only way that would work (I think) is if I could wet the wood comprising the main body of the panel...the stuff under the veneer. I'd have to peel off all the old veneer to do that. I also thought about placing a temporary brace inside, centered on the warped areas that would push out on the center of the panel, while I clamped the front and rear to create a "reversed cup" and see if the wood would re-set. I'm worried about cracking the panel though. The cup is not really THAT noticeable unless you have a straightedge, or better eyes than me. But I'd still like to get the panels as straight as possible. The seams between the side panels and the front panel have opened up from the cupping, about the thickness of a piece of old veneer, creating a noticeable gap there too.
In everyone's opinion what is best?...keep the original panels even though they are not straight in order to preserve as much originality as possible? (same for the veneer, keep as much as possible or replace?), insert permanent bracing inside to pull the panels straighter even though that would detract from originality as well?, or possibly look into getting new panels made? If I keep the original panels, what is the best way to fill the seams that have gapped without making it look like he**. How much should I really spend on this radio before I get into the realm of wasting time, money and effort?
Thanks guys, just want to make sure I don't "Bubba" up a nice piece of history any more than is necessary. This is a learning process for me.
RE: Veneer repair and finish advice for Philco 14MX - by Groundhog74 - 06-04-2013, 07:40 AM
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
There are currently 2663 online users. [Complete List]
» 1 Member(s) | 2662 Guest(s)
