Philco 60MB cabinet restoration
#37
I finished off the masking and proceeded to spray on the black.
[Image: http://farm6.staticflickr.com/5464/89486...be63_c.jpg]
All was well until I got to this area and fisheyes appeared. I'll sand it down, apply more sealer and try again.
[Image: http://farm4.staticflickr.com/3820/89492...8e21_c.jpg]
Philco 60MB cabinet restoration - by Bob Andersen - 04-06-2013, 06:57 PM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 07:46 AM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 04:26 PM
RE: Philco 60MB cabinet restoration - by Art Hoch - 04-07-2013, 05:40 PM
RE: Philco 60MB cabinet restoration - by Geoff - 04-08-2013, 11:57 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-09-2013, 10:38 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-21-2013, 11:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-04-2013, 12:48 AM
RE: Philco 60MB cabinet restoration - by Arran - 05-09-2013, 06:45 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-17-2013, 08:20 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-18-2013, 08:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-20-2013, 11:54 PM
RE: Philco 60MB cabinet restoration - by jph14 - 05-22-2013, 04:46 PM
RE: Philco 60MB cabinet restoration - by Bob Andersen - 06-04-2013, 11:29 AM
RE: Philco 60MB cabinet restoration - by EricS - 08-24-2013, 09:22 PM
There are currently 10222 online users. [Complete List]
» 2 Member(s) | 10220 Guest(s)
