How many Philco 38-116 radios are out there?
I corrected your post, PhilcoJohn. You can also edit your own posts by clicking the Edit button in the lower right corner of any of your posts, and make whatever changes you need to make.
We know Philco made 25,600 of the 38-116 sets. How many remain, I have no way of knowing.
RE: How many Philco 38-116 radios are out there? - by Ron Ramirez - 06-04-2013, 08:41 PM
Philco 91 Tuning Condenser
