  • 1 Vote(s) - 5 Average
Ron's Cabinet Work for the 2013 Season
#31
Blah, blah, blah, the sky is falling, the sky is falling! I've got modern chairs where the legs are falling apart, but I've got over 200 seventy plus year old radio cabinets that are still solid and tight. Hmmm, do I want to take advice from guys who assemble and restore cabinets for a living, or a self professed internet "expert" who claims he knows a guy who tried some pre-mixed glue that failed. OK, that was an easy decision.
RE: Ron's Cabinet Work for the 2013 Season - by Eliot Ness - 06-05-2013, 02:05 AM
Users browsing this thread: 17 Guest(s)
There are currently 10554 online users. [Complete List]
» 2 Member(s) | 10552 Guest(s)
