RCA 8X71-Hum
Agree, try moving set around. Most likely a really old dimmer, imported unshielded power supply, shut your bench down completely first.
RCA 8X71-Hum - by Eric Adams - 06-05-2013, 12:57 PM
RE: RCA 8X71-Hum - by BrendaAnnD - 06-05-2013, 04:39 PM
RE: RCA 8X71-Hum - by codefox1 - 06-05-2013, 06:17 PM
RE: RCA 8X71-Hum - by Eric Adams - 06-06-2013, 02:27 AM
There are currently 10208 online users. [Complete List]
» 3 Member(s) | 10205 Guest(s)
