RCA 8X71-Hum
Thanks BrendaAnnD, out of the basement and away from my bench the hum is minimized. It's just strange that this is the only radio that I've had this issue with.
Eric
The Villages, FL
RCA 8X71-Hum - by Eric Adams - 06-05-2013, 12:57 PM
RE: RCA 8X71-Hum - by BrendaAnnD - 06-05-2013, 04:39 PM
RE: RCA 8X71-Hum - by codefox1 - 06-05-2013, 06:17 PM
RE: RCA 8X71-Hum - by Eric Adams - 06-06-2013, 02:27 AM
There are currently 6782 online users. [Complete List]
» 4 Member(s) | 6778 Guest(s)
AvatarAvatarAvatarAvatar
