37-650 or not?
Hi Gary
You can use either a Type 44 or a Type 55 in your 1937 shadowmeter.
Good luck and enjoy, Ron.
37-650 or not? - by n9vu - 01-11-2008, 01:13 AM
[No subject] - by Ron Ramirez - 01-11-2008, 08:11 AM
[No subject] - by n9vu - 01-11-2008, 09:49 AM
[No subject] - by n9vu - 01-15-2008, 07:46 AM
[No subject] - by Ron Ramirez - 01-15-2008, 08:22 AM
[No subject] - by planigan - 03-02-2008, 01:57 AM
[No subject] - by Ron Ramirez - 03-02-2008, 09:38 AM
Philco 91 Tuning Condenser
There are currently 6857 online users. [Complete List]
» 2 Member(s) | 6855 Guest(s)
