In honor of D Day
As a kid in the 50's I remember the incredible amount of WW II
surplus equipment available to the public.
This included every type of electronic equipment imaginable and it
was labeled JAN (joint Army-Navy) made by Philco, GE, RCA,
Ken Rad, National Union, Westinghouse and others.
Its amazing how sophisticated and dependable this equipment was from an industry barely out of its infancy, I guess it had to grow up
very fast.
In honor of D Day - by chris25260880 - 06-06-2013, 03:15 PM
RE: In honor of D Day - by Paul Philco322 - 06-07-2013, 09:40 PM
RE: In honor of D Day - by Bill Kinghorn - 06-07-2013, 11:54 PM
Philco 91 Tuning Condenser
