Newbie Please Help!!! Philco 610 Electro. Capacitor Dilemma
Hi
Just be sure that when you installed new electrolytics, that you COMPLETELY disconnected the old electrolytics from the circuit! Otherwise, the radio is going to eventually fail anyway because of the faulty old electrolytics. And if one of the old ones shorts...it could take out your set's power transformer.
[No subject] - by TonyJSenior - 01-13-2008, 08:14 PM
Thanks TonyJSenior - by Guest - 01-13-2008, 10:22 PM
[No subject] - by TonyJSenior - 01-14-2008, 07:55 AM
[No subject] - by TonyJSenior - 01-14-2008, 08:00 AM
Thanks again TonyJSenior - by Guest - 01-14-2008, 09:47 AM
Eureka!!! - by Guest - 01-14-2008, 11:36 AM
[No subject] - by TonyJSenior - 01-14-2008, 01:13 PM
[No subject] - by Ron Ramirez - 01-16-2008, 11:45 PM
Hey Ron - by Guest - 01-17-2008, 01:49 AM
There are currently 10194 online users. [Complete List]
» 3 Member(s) | 10191 Guest(s)
