  • 1 Vote(s) - 5 Average
Ron's Cabinet Work for the 2013 Season
#39
Well, I have to tell you, that my nose does not work very well after years of sinus problems. That said, no, the CrystaLac does not smell like either acetone or lacquer thinner. It's water based, actually.
RE: Ron's Cabinet Work for the 2013 Season - by Ron Ramirez - 06-06-2013, 07:12 PM
Users browsing this thread: 18 Guest(s)
There are currently 11440 online users. [Complete List]
» 2 Member(s) | 11438 Guest(s)
