38-116 toner colores
After 3 tries on grain filling it must have gone bad it never really got dry so I order some Constantines Walnut grain filler hope it works.
Been reading post here by Ron I am going to try the ideas in those post.
38-116 toner colores - by vinzer - 05-28-2013, 10:12 PM
RE: 38-116 toner colors - by vinzer - 06-02-2013, 09:42 PM
RE: 38-116 toner colores - by Ron Ramirez - 06-03-2013, 05:33 AM
RE: 38-116 toner colores - by vinzer - 06-03-2013, 11:41 AM
RE: 38-116 toner colors - by vinzer - 06-06-2013, 11:26 PM
There are currently 8925 online users. [Complete List]
» 3 Member(s) | 8922 Guest(s)
