Zenith 10-S-669 for 20 dollars
Rocketeer....nice radio! Mine actually has a belt on the primary (?) pulley but the secondary that goes up to the tuning shaft has a dial cord on it. Maybe a repairman's mod? The rubber piece that the belt rides on is there, but looks like it could crumble into dust at any moment. I'll do the electrical tape deal first when I get the new belt and see how that works.
I was talking about the radio organ switches. (New to Zenith consoles and the terminology). They are making contact, but kinda loose. I cleaned them a little and will probably tighten them up and re-clean them when I do the re-cap. The wire bundle coming from the radio organ assembly was basically all bare wire as the rubber coating had disappeared at some point. Before I tried it out, I recovered all of that wiring, and any under the chassis that was exposed, or looked like it might remotely be a shorting hazard. I learned that lesson the hard way on a Philco 42-380. I am also going to order some more authentic grill cloth. I just had to temporarily replace the dirty, moldy original stuff so the wife would let me bring it in the house Icon_biggrin
Zenith 10-S-669 for 20 dollars - by Groundhog74 - 05-30-2013, 07:11 AM
RE: Zenith 10-S-669 for 20 dollars - by morzh - 05-30-2013, 08:51 AM
RE: Zenith 10-S-669 for 20 dollars - by rocketeer - 06-06-2013, 08:46 AM
RE: Zenith 10-S-669 for 20 dollars - by morzh - 06-06-2013, 08:57 AM
RE: Zenith 10-S-669 for 20 dollars - by rocketeer - 06-06-2013, 09:51 AM
RE: Zenith 10-S-669 for 20 dollars - by rocketeer - 06-06-2013, 04:56 PM
RE: Zenith 10-S-669 for 20 dollars - by Steve D - 06-06-2013, 05:08 PM
RE: Zenith 10-S-669 for 20 dollars - by morzh - 06-06-2013, 06:58 PM
RE: Zenith 10-S-669 for 20 dollars - by Groundhog74 - 06-07-2013, 06:55 AM
