In honor of D Day
I have a lot of war time issued tubes, VT's. I look at some of the old timers left from WW2 and they remind me of my Dad. Did what they had to do. My father told me that not only did most people celebrate the war ending but that a lot sort of viewed the Depression and the War as one big trial, they finally felt like things were looking up. We would not have what we do if they had failed.
In honor of D Day - by chris25260880 - 06-06-2013, 03:15 PM
RE: In honor of D Day - by Paul Philco322 - 06-07-2013, 09:40 PM
RE: In honor of D Day - by Bill Kinghorn - 06-07-2013, 11:54 PM
Philco 91 Tuning Condenser
There are currently 5381 online users. [Complete List]
» 1 Member(s) | 5380 Guest(s)
