philco consoles with back covers
Congrats. I wish my 38-1 had its back. The swivel clips are about half there.
philco consoles with back covers - by murf - 06-07-2013, 11:22 PM
RE: philco consoles with back covers - by Art Hoch - 06-08-2013, 07:56 PM
Philco 91 Tuning Condenser
