What's missing from this cabinet?
The glass is missing, along with the knobs and grille cloth.
Either the case was striped or it's the wrong case for the chassis.
Here is a 39-6 from Radio Attic gallery: http://radioatticarchives.com/radio.php?radio=2004
[No subject] - by Chuck Schwark - 01-17-2008, 10:02 AM
[No subject] - by TonyJSenior - 01-17-2008, 11:02 AM
[No subject] - by Ron Ramirez - 01-19-2008, 02:44 PM
Philco 91 Tuning Condenser
