Question about Philco 80 Jr.
Have you looked at the audio level on the grid of the 42 with a scope? It sure seems like an audio problem, but there is not much there to go wrong. I would try and measure the P-P audio level on the 42 grid and compare it to what you have on the plate. About 26V P-P should drive a 42 to full output, so if you have good drive but low output you might then check the output transformer or speaker for problems.
I doubt the problem would be the 36 detector as you can get regeneration, but you can switch it with the converter 36 to check and see if it makes a difference. Maybe a bad coupling cap or detector plate load resistor?
Question about Philco 80 Jr. - by BrendaAnnD - 06-08-2013, 03:20 PM
RE: Question about Philco 80 Jr. - by Mondial - 06-08-2013, 04:20 PM
RE: Question about Philco 80 Jr. - by morzh - 06-08-2013, 05:16 PM
RE: Question about Philco 80 Jr. - by 7estatdef - 06-08-2013, 06:15 PM
RE: Question about Philco 80 Jr. - by morzh - 06-08-2013, 06:32 PM
RE: Question about Philco 80 Jr. - by BrendaAnnD - 06-08-2013, 08:51 PM
RE: Question about Philco 80 Jr. - by Mondial - 06-08-2013, 09:17 PM
RE: Question about Philco 80 Jr. - by 7estatdef - 06-08-2013, 09:36 PM
RE: Question about Philco 80 Jr. - by Phlogiston - 06-09-2013, 12:15 AM
RE: Question about Philco 80 Jr. - by BrendaAnnD - 06-09-2013, 02:22 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 1642 online users. [Complete List]
» 2 Member(s) | 1640 Guest(s)
