I would use wood glue like elmers.
glue - by w4rtc - 06-08-2013, 07:15 PM
RE: glue - by vinzer - 06-08-2013, 10:22 PM
RE: glue - by Bill Kinghorn - 06-08-2013, 10:46 PM
RE: glue - by Eric Adams - 06-08-2013, 11:02 PM
RE: glue - by jerryhawthorne - 06-09-2013, 01:20 AM
RE: glue - by TA Forbes - 06-09-2013, 10:37 AM
RE: glue - by w4rtc - 06-09-2013, 08:56 PM
RE: glue - by jerryhawthorne - 06-09-2013, 10:37 PM
Philco 91 Tuning Condenser
There are currently 3990 online users. [Complete List]
» 1 Member(s) | 3989 Guest(s)
