How many Philco 38-116 radios are out there?
I have owned one for almost 40 years, and it is now getting a complete restoration. The biggest issues were a defective audio driver transformer and a cracked dial; both have been replaced.
Tim KA3JRT
RE: How many Philco 38-116 radios are out there? - by Tim Tress - 06-08-2013, 11:14 PM
There are currently 5651 online users. [Complete List]
» 4 Member(s) | 5647 Guest(s)
AvatarAvatarAvatarAvatar
