Philco Model 48 - 1256
I received this model for Christmas and I don't have the proper speaker for it. Does anyone know what type of speaker I should put into it?
Matt
Philco Model 48 - 1256 - by Matt-Morley - 06-10-2013, 12:20 AM
RE: Philco Model 48 - 1256 - by klondike98 - 06-10-2013, 09:13 AM
Philco 91 Tuning Condenser
There are currently 9386 online users. [Complete List]
» 1 Member(s) | 9385 Guest(s)
