Philco H-1 Lamp
I am restoring a Philco 41-629 Beam of Light phono and need to know what type of neon lamp was used in the H-1 recorder unit.
Also will need to know where to get them.
Thanks in advance foor any help.
Philco H-1 Lamp - by PFJC2 - 06-10-2013, 05:19 PM
RE: Philco H-1 Lamp - by marv - 06-11-2013, 04:46 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-12-2013, 09:02 AM
RE: Philco H-1 Lamp - by marv - 06-16-2013, 01:19 PM
RE: Philco H-1 Lamp - by Chuck Schwark - 06-16-2013, 11:18 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-17-2013, 10:18 AM
RE: Philco H-1 Lamp - by oldgoaly - 06-18-2013, 02:55 PM
RE: Philco H-1 Lamp - by marv - 06-18-2013, 04:10 PM
Philco 91 Tuning Condenser
There are currently 9323 online users. [Complete List]
» 1 Member(s) | 9322 Guest(s)
