What's missing from this cabinet?
Tony
Take a good look at the photos showing the back of the cabinet. Clearly, the cabinet was originally painted ivory...and later stripped.
The ivory painted 39-6 cabinets should have a metal bezel and dial glass. Walnut 39-6 models only have a plastic dial cover, no metal bezel. So Chuck is right, the dial glass and bezel are missing from this set...
[No subject] - by Chuck Schwark - 01-17-2008, 10:02 AM
[No subject] - by TonyJSenior - 01-17-2008, 11:02 AM
[No subject] - by Ron Ramirez - 01-19-2008, 02:44 PM
