Any idea on details of this Philco?
Please, do not start multiple threads on the same subject. A lot of us work for a living (myself included) and cannot provide immediate responses.
Continue discussion here:
http://philcoradio.com/phorum/showthread.php?tid=6839
This thread is locked.
Any idea on details of this Philco? - by hchearne - 06-11-2013, 12:48 PM
RE: Any idea on details of this Philco? - by Ron Ramirez - 06-11-2013, 04:31 PM
Philco 91 Tuning Condenser
