Philco H-1 Lamp
The Philco part number is 34-2432, probably not much help. They are 105-125 volt. Here is a pic of the ones in mine. (I have a 41-629).
[Image: http://i266.photobucket.com/albums/ii273...97cc23.jpg]
Philco H-1 Lamp - by PFJC2 - 06-10-2013, 05:19 PM
RE: Philco H-1 Lamp - by marv - 06-11-2013, 04:46 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-12-2013, 09:02 AM
RE: Philco H-1 Lamp - by marv - 06-16-2013, 01:19 PM
RE: Philco H-1 Lamp - by Chuck Schwark - 06-16-2013, 11:18 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-17-2013, 10:18 AM
RE: Philco H-1 Lamp - by oldgoaly - 06-18-2013, 02:55 PM
RE: Philco H-1 Lamp - by marv - 06-18-2013, 04:10 PM
Philco 91 Tuning Condenser
