Philco 18" speakers-I did not know.
Those speakers look like they were pulled out of a cabinet stereo of some kind. $375 for the set? I don't think so since you probably couldn't give away the unit they came out of.
Philco 18" speakers-I did not know. - by y2kbruce - 06-11-2013, 07:20 PM
RE: Philco 18" speakers-I did not know. - by Arran - 06-11-2013, 08:37 PM
Philco 91 Tuning Condenser
There are currently 7089 online users. [Complete List]
» 3 Member(s) | 7086 Guest(s)
