Condenser is a 30-4455s but schematic says it's a 30-4170???
I am about to recap my Philco 37-650, but one of the original paper caps, a 30-4455 is represented in the schematic as a 30-4170.
How can this be and which one is it? Any advice?
Thanks in advance!
Condenser is a 30-4455s but schematic says it's a 30-4170??? - by Guest - 01-19-2008, 06:40 PM
[No subject] - by Ron Ramirez - 01-19-2008, 06:55 PM
Thanks Ron! - by Guest - 01-19-2008, 07:27 PM
There are currently 10482 online users. [Complete List]
» 2 Member(s) | 10480 Guest(s)
