Philco 49-906 help needed
Gary,
I did find the "floating" ground. I finally got to power it up. I did recieve some garlbed stations on AM but nothing on AM. I have the troubleshooting guide for the audio sections. Is there something obvious I should look for? It was motorboating also.
thanks
Chris
Philco 49-906 help needed - by Chris Drumma - 01-19-2008, 09:02 AM
[No subject] - by gary rabbitt - 01-19-2008, 03:21 PM
[No subject] - by Chris Drumma - 01-19-2008, 07:43 PM
[No subject] - by gary rabbitt - 01-23-2008, 12:57 AM
There are currently 9788 online users. [Complete List]
» 2 Member(s) | 9786 Guest(s)
