Any ideas what model?
I have that set in BG cabinet. It's a farm set that runs on batteries. With that being said it a good playing set. Push pull pentode output which will put out about 2 watts of audio. Would mind finding one but you don't find too many farm set here near Philly. My 37-33 came from a meet in Ky 25yrs ago
Any ideas what model? - by Skip - 06-13-2013, 07:01 AM
RE: Any ideas what model? - by Ron Ramirez - 06-13-2013, 10:44 AM
RE: Any ideas what model? - by Skip - 06-13-2013, 09:31 PM
RE: Any ideas what model? - by 7estatdef - 06-14-2013, 10:13 PM
Philco 91 Tuning Condenser
