Philco furniture plant number 4.
I'm working on a Philco 201x, and it has a stamp of Philco Furniture Plant #3. Ron, I clicked on the link you provided, and it doesn't show me anything. I'm sure you have updated your website a lot since this original post.
How do I find out where Plant 3 was? This is all new to me!!!
Thank you
Chris
Note: I found it! It is now the 9th section of the Philco history. Thanks for all the great background!
Philco furniture plant number 4. - by Drew - 11-19-2007, 03:42 PM
RE: Philco furniture plant number 4. - by cwysong - 06-15-2013, 11:44 AM
RE: Philco furniture plant number 4. - by GarySP - 06-16-2013, 09:41 AM
Philco 91 Tuning Condenser
There are currently 5607 online users. [Complete List]
» 1 Member(s) | 5606 Guest(s)
