Model 95 wire resistor question
Hmmm...something is causing resistor (49) to draw way too much current! In normal operation it should run cool.
Line "C" is the main B+ coming out of the filter network. A quick way to check this is to measure the resistance between terminal 9 of the large filter cap block ( 48 ) and ground, with the set UNPLUGGED.
Questions:
* Do you have the complete service info for this set yet?
* If not, have you contacted Chuck at the link I gave you above?
You are really going to need to see more than just the schematic; and you need the complete service data for that. I have the Model 95 manual (16 pages) in high-resolution PDF format; I can send it to you if you have a broadband connection (13 MB). If you're on dialup it is better to order from Chuck.
Let me know...
EDIT: Yes, the long ceramic resistor is 8300 ohms and the shorter ceramic unit is 800. If these measure okay, that's a very good thing.
Model 95 wire resistor question - by Guest - 11-11-2005, 05:47 PM
[No subject] - by Ron Ramirez - 11-11-2005, 09:55 PM
[No subject] - by Guest - 11-13-2005, 01:22 PM
[No subject] - by Ron Ramirez - 11-13-2005, 01:25 PM
[No subject] - by Guest - 11-15-2005, 01:40 PM
[No subject] - by Ron Ramirez - 11-17-2005, 12:08 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9853 online users. [Complete List]
» 3 Member(s) | 9850 Guest(s)
