Philco furniture plant number 4.
Geez Ron!!! Is there anything you DON'T know about the history of Philco? It seems like you just pull this stuff out of thin air!! Sure glad you share it! Take care, Gary.
Philco furniture plant number 4. - by Drew - 11-19-2007, 03:42 PM
RE: Philco furniture plant number 4. - by cwysong - 06-15-2013, 11:44 AM
RE: Philco furniture plant number 4. - by GarySP - 06-16-2013, 09:41 AM
Philco 91 Tuning Condenser
