  • 1 Vote(s) - 5 Average
Ron's Cabinet Work for the 2013 Season
#58
OK, if anyone's still following along, here's a look at today's progress.
I carefully wet sanded the 610T cabinet with 400 grit wet/dry paper. I ended up having to mask off the cabinet and re-tone the bottom trim on front. Later, it received a few more coats of clear Deft. As far as I am concerned...it is done. Not quite as good as it would have been, but still pretty good. Photos later.
I also applied grain filler to both sides of the 38-2670B cabinet. It will be ready for lacquer this coming week.
RE: Ron's Cabinet Work for the 2013 Season - by Ron Ramirez - 06-16-2013, 04:24 PM
Users browsing this thread: 21 Guest(s)
There are currently 11381 online users. [Complete List]
» 2 Member(s) | 11379 Guest(s)
