My new 39-55
Oops! Sorry about that. I'm running around trying to get things put away before it gets too dark. Getting absent minded in my advancing yearsIcon_redface! I took the mystery control cover off and it appears to have the original bettery pack still installed as well as a Philco 30 Tube, pretty neat. Also the wiring is still in beautiful condition.
[Image: http://i1160.photobucket.com/albums/q500...7b1eef.jpg]
[Image: http://i1160.photobucket.com/albums/q500...150e4c.jpg]
[Image: http://i1160.photobucket.com/albums/q500...711edf.jpg]
[Image: http://i1160.photobucket.com/albums/q500...0ee101.jpg]
[Image: http://i1160.photobucket.com/albums/q500...bb01f0.jpg]
[Image: http://i1160.photobucket.com/albums/q500...f1c48d.jpg]
[Image: http://i1160.photobucket.com/albums/q500...8cfdc7.jpg]
My new 39-55 - by 37silverstreak - 06-16-2013, 09:20 PM
RE: My new 39-55 - by Ron Ramirez - 06-16-2013, 09:36 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 09:50 PM
RE: My new 39-55 - by morzh - 06-16-2013, 10:41 PM
RE: My new 39-55 - by Chuck Schwark - 06-16-2013, 11:16 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 11:42 PM
RE: My new 39-55 - by NostalgiaRadioTime - 06-16-2013, 11:51 PM
RE: My new 39-55 - by Chuck Schwark - 06-17-2013, 09:01 AM
RE: My new 39-55 - by ipwizard - 06-17-2013, 05:38 PM
RE: My new 39-55 - by Jayce - 06-17-2013, 08:09 PM
RE: My new 39-55 - by Arran - 06-17-2013, 08:21 PM
RE: My new 39-55 - by w4rtc - 06-17-2013, 09:15 PM
RE: My new 39-55 - by 37silverstreak - 06-17-2013, 10:43 PM
RE: My new 39-55 - by Arran - 06-18-2013, 10:12 PM
Philco 91 Tuning Condenser
There are currently 8965 online users. [Complete List]
» 2 Member(s) | 8963 Guest(s)
