My new 39-55
I see the Mystery Control frequency is a Code 6 on the radio chassis rear. Is there a corresponding "6" inside the Mystery Control? If so, then, the MC is the original to the set. Otherwise the MC can be re-tuned to match your set. BatteryMaker, a member here, can provide a repro MC control battery for you.
Good catch,
Chuck
My new 39-55 - by 37silverstreak - 06-16-2013, 09:20 PM
RE: My new 39-55 - by Ron Ramirez - 06-16-2013, 09:36 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 09:50 PM
RE: My new 39-55 - by morzh - 06-16-2013, 10:41 PM
RE: My new 39-55 - by Chuck Schwark - 06-16-2013, 11:16 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 11:42 PM
RE: My new 39-55 - by NostalgiaRadioTime - 06-16-2013, 11:51 PM
RE: My new 39-55 - by Chuck Schwark - 06-17-2013, 09:01 AM
RE: My new 39-55 - by ipwizard - 06-17-2013, 05:38 PM
RE: My new 39-55 - by Jayce - 06-17-2013, 08:09 PM
RE: My new 39-55 - by Arran - 06-17-2013, 08:21 PM
RE: My new 39-55 - by w4rtc - 06-17-2013, 09:15 PM
RE: My new 39-55 - by 37silverstreak - 06-17-2013, 10:43 PM
RE: My new 39-55 - by Arran - 06-18-2013, 10:12 PM
Philco 91 Tuning Condenser
There are currently 9432 online users. [Complete List]
» 1 Member(s) | 9431 Guest(s)
