Philco H-1 Lamp
I believe that will work fine. Same voltage specs and electrode shape.
Dbl contact base and all.
Chuck
Philco H-1 Lamp - by PFJC2 - 06-10-2013, 05:19 PM
RE: Philco H-1 Lamp - by marv - 06-11-2013, 04:46 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-12-2013, 09:02 AM
RE: Philco H-1 Lamp - by marv - 06-16-2013, 01:19 PM
RE: Philco H-1 Lamp - by Chuck Schwark - 06-16-2013, 11:18 PM
RE: Philco H-1 Lamp - by PFJC2 - 06-17-2013, 10:18 AM
RE: Philco H-1 Lamp - by oldgoaly - 06-18-2013, 02:55 PM
RE: Philco H-1 Lamp - by marv - 06-18-2013, 04:10 PM
Philco 91 Tuning Condenser
