My new 39-55
Very nice when you get the set and original control with Mystery sets.
Patience is needed, as you can see from the chassis. ;)
Good luck,
Chuck
My new 39-55 - by 37silverstreak - 06-16-2013, 09:20 PM
RE: My new 39-55 - by Ron Ramirez - 06-16-2013, 09:36 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 09:50 PM
RE: My new 39-55 - by morzh - 06-16-2013, 10:41 PM
RE: My new 39-55 - by Chuck Schwark - 06-16-2013, 11:16 PM
RE: My new 39-55 - by 37silverstreak - 06-16-2013, 11:42 PM
RE: My new 39-55 - by NostalgiaRadioTime - 06-16-2013, 11:51 PM
RE: My new 39-55 - by Chuck Schwark - 06-17-2013, 09:01 AM
RE: My new 39-55 - by ipwizard - 06-17-2013, 05:38 PM
RE: My new 39-55 - by Jayce - 06-17-2013, 08:09 PM
RE: My new 39-55 - by Arran - 06-17-2013, 08:21 PM
RE: My new 39-55 - by w4rtc - 06-17-2013, 09:15 PM
RE: My new 39-55 - by 37silverstreak - 06-17-2013, 10:43 PM
RE: My new 39-55 - by Arran - 06-18-2013, 10:12 PM
Philco 91 Tuning Condenser
There are currently 4292 online users. [Complete List]
» 2 Member(s) | 4290 Guest(s)
