buting new tubes
Hi Sam,
If you are new to the radio restoration, you might want to read a little bit about the operation of these sets. If you just bought a Philco 90 (which there are some variations) and powered it up and it did not work, the tubes may actually be fine.
There are other parts that must be replaced like the filter capacitors.
Often replacing these will bring the set back to life.
(Rebuilding bakelite block caps are a whole different subject, but they are easy to do.)
Appplying power to a set that had not been serviced can result in damage to irreplaceable or expensive parts like the transformer.
If you haven't read this you may find it informative.
http://www.philcoradio.com/tech/plugin.htm
You have a nice model set there, and we would not like to hear that something burned up,(by just replacing tubes only) requiring more work. A little cheap insurance (preliminary tests anf canging capacitors) is cheap insurance that you will not damage anything.
Take care,
Gary Rabbitt [Image: http://www.grabbittradios.com/radio/emoticon.gif]
buting new tubes - by Guest - 01-20-2008, 03:59 PM
[No subject] - by TonyJSenior - 01-20-2008, 04:10 PM
[No subject] - by gary rabbitt - 01-22-2008, 11:36 PM
There are currently 10725 online users. [Complete List]
» 2 Member(s) | 10723 Guest(s)
