Troubleshooting a Philco 47-1230
Chuck's site the best. So far I know it is a self-liquidating hobby at very best. You will get the best. Indepedent, not associated,... and so on.
Troubleshooting a Philco 47-1230 - by Warren - 06-17-2013, 11:37 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 06-18-2013, 07:36 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 06-19-2013, 12:10 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 06-19-2013, 01:40 PM
RE: Troubleshooting a Philco 47-1230 - by codefox1 - 06-20-2013, 02:30 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-04-2013, 06:03 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 07-04-2013, 06:17 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-04-2013, 06:57 PM
RE: Troubleshooting a Philco 47-1230 - by Arran - 07-05-2013, 12:42 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-05-2013, 12:57 AM
RE: Troubleshooting a Philco 47-1230 - by GarySP - 07-05-2013, 03:32 PM
RE: Troubleshooting a Philco 47-1230 - by Arran - 07-05-2013, 09:18 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-05-2013, 10:48 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 07-05-2013, 10:59 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-06-2013, 12:11 AM
RE: Troubleshooting a Philco 47-1230 - by GarySP - 07-06-2013, 10:31 AM
Philco 91 Tuning Condenser
