How many Philco 38-116 radios are out there?
If you didn't an easy way to do it is to remove the bandwitch shaft it is held in by 2 screw on the front unsolder the grounds of metal shields and remove the screw that holds them in then you can move them around to get at the caps.
RE: How many Philco 38-116 radios are out there? - by vinzer - 06-21-2013, 05:01 PM
Philco 91 Tuning Condenser
There are currently 5732 online users. [Complete List]
» 1 Member(s) | 5731 Guest(s)
