Interesting custom Philco cabinet
Furniture back in those day could best be described as "busy" or "gaudy" nothing sleek or minimalist. Old homes with bad taste furnishings like this are definitely not my style, reminds me of the house in Singing in the Rain or some of the old Three Stooges shorts done in this type of mausoleum home complete with matronly women. The comic strip Blondie after all these years finally replaced a TV with legs like this with a flat screen HDTV because few of their readers would have known what it was
Interesting custom Philco cabinet - by Skip - 06-20-2013, 12:14 AM
RE: Interesting custom Philco cabinet - by Skip - 06-21-2013, 12:56 PM
RE: Interesting custom Philco cabinet - by chris25260880 - 06-21-2013, 07:29 PM
RE: Interesting custom Philco cabinet - by morzh - 06-21-2013, 10:57 PM
RE: Interesting custom Philco cabinet - by Arran - 06-28-2013, 01:06 AM
Philco 91 Tuning Condenser
