How many Philco 38-116 radios are out there?
Tim, What are you saying? Should I try swaping out the 6A8G tube? If that is what you think would make the radio tune better I will give it a try... I will try to locate one.
RE: How many Philco 38-116 radios are out there? - by PhilcoJohn - 06-21-2013, 08:59 PM
Philco 91 Tuning Condenser
