  • 1 Vote(s) - 5 Average
Ron's Cabinet Work for the 2013 Season
#71
Very wise advice on using a good two stage respirator; by the time you realize you should have, it may be too late.
That 42-22CL is a pretty neat looking set and it's turning out very nice!
RE: Ron's Cabinet Work for the 2013 Season - by Eliot Ness - 06-22-2013, 12:59 AM
Users browsing this thread: 18 Guest(s)
There are currently 10313 online users. [Complete List]
» 1 Member(s) | 10312 Guest(s)
