Unknown Emerson
Judging by the schematic it looks like a fairly straightforward radio to work on, a single band and about ten paper caps and two electrolytics to replace. It also has a tuned RF amplifier stage so it's probably a reasonable performer. I think the biggest issue will be repairing or replicating that grille, but it looks like the front panel could be removed to work on it.
Unknown Emerson - by Jayce - 06-23-2013, 09:07 PM
RE: Unknown Emerson - by BrendaAnnD - 06-23-2013, 09:33 PM
RE: Unknown Emerson - by Jayce - 06-23-2013, 10:02 PM
RE: Unknown Emerson - by Eliot Ness - 06-23-2013, 10:32 PM
RE: Unknown Emerson - by Jayce - 06-23-2013, 11:28 PM
RE: Unknown Emerson - by Arran - 06-24-2013, 12:40 AM
RE: Unknown Emerson - by BrendaAnnD - 06-24-2013, 01:05 AM
RE: Unknown Emerson - by 7estatdef - 06-24-2013, 08:01 AM
RE: Unknown Emerson - by BrendaAnnD - 06-24-2013, 09:43 AM
RE: Unknown Emerson - by Jayce - 06-24-2013, 12:01 PM
RE: Unknown Emerson - by TA Forbes - 06-25-2013, 11:53 AM
There are currently 7480 online users. [Complete List]
» 1 Member(s) | 7479 Guest(s)
