Model 620, resistor failed
Hi;
Was finishing up recaping the 620 when part 49, 20,000 resistor broke. Does any one know what voltage rating it should be and where I might get a replacement. Thanks.
God bless,
Dave
Model 620, resistor failed - by David B - 01-28-2008, 12:12 PM
[No subject] - by rghines1 - 01-29-2008, 07:45 AM
Philco 620 - by David B - 01-29-2008, 08:31 PM
There are currently 10073 online users. [Complete List]
» 1 Member(s) | 10072 Guest(s)
