Model 80 Compact alignment
Hello Terry,
While waiting I checked the sensitivity with my signal generator. It is consistant across the entire dial. I think the answer is antenna and low power stations low on the band. I think that I will try my tuned loop antenna this evening. It really sucks in the stations.
The antenna and ground wires come out of the chassis and just end. I was thinking about a couple of fanestock clips. Any thoughts?
keithw
Model 80 Compact alignment - by barshnik - 06-25-2013, 03:31 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 03:53 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 05:57 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 06:37 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 09:36 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 11:05 PM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 12:11 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:26 AM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 01:15 AM
RE: Model 80 Compact alignment - by Arran - 06-26-2013, 01:38 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 08:49 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 10:44 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 11:19 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 11:47 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:17 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 12:27 PM
RE: Model 80 Compact alignment - by Mondial - 06-26-2013, 01:48 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-26-2013, 06:05 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 06:55 PM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 09:40 PM
RE: Model 80 Compact alignment - by barshnik - 06-26-2013, 10:35 PM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 12:12 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-27-2013, 05:09 AM
RE: Model 80 Compact alignment - by morzh - 06-27-2013, 09:23 AM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 09:33 AM
RE: Model 80 Compact alignment - by barshnik - 06-27-2013, 10:30 PM
RE: Model 80 Compact alignment - by codefox1 - 06-28-2013, 08:06 AM
RE: Model 80 Compact alignment - by 7estatdef - 06-29-2013, 06:26 PM
RE: Model 80 Compact alignment - by keithw - 07-16-2013, 10:53 PM
There are currently 9034 online users. [Complete List]
» 1 Member(s) | 9033 Guest(s)
