Model 80 Compact alignment
Yep, the regen is the last step of the alignment. A little too much and it sounds like mush and then starts oscillating. I set it as high as I could without it getting ugly. We did find a performance increase mod that we will try once we are sure we have it sorted out in stock form. With a decent antenna I am pretty happy with it. It has plenty of volume but just doesn't want to pull signals out of the grass. The tubes all tested good but one may be a bit weak. If we ever come across another one of these the first place I am looking is the IF. That 460 vs 230 thing is just bugging me.
keithw
Model 80 Compact alignment - by barshnik - 06-25-2013, 03:31 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 03:53 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 05:57 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 06:37 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 09:36 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 11:05 PM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 12:11 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:26 AM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 01:15 AM
RE: Model 80 Compact alignment - by Arran - 06-26-2013, 01:38 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 08:49 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 10:44 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 11:19 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 11:47 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:17 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 12:27 PM
RE: Model 80 Compact alignment - by Mondial - 06-26-2013, 01:48 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-26-2013, 06:05 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 06:55 PM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 09:40 PM
RE: Model 80 Compact alignment - by barshnik - 06-26-2013, 10:35 PM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 12:12 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-27-2013, 05:09 AM
RE: Model 80 Compact alignment - by morzh - 06-27-2013, 09:23 AM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 09:33 AM
RE: Model 80 Compact alignment - by barshnik - 06-27-2013, 10:30 PM
RE: Model 80 Compact alignment - by codefox1 - 06-28-2013, 08:06 AM
RE: Model 80 Compact alignment - by 7estatdef - 06-29-2013, 06:26 PM
RE: Model 80 Compact alignment - by keithw - 07-16-2013, 10:53 PM
There are currently 9645 online users. [Complete List]
» 2 Member(s) | 9643 Guest(s)
